edsareg Posted August 11, 2022 Share Posted August 11, 2022 Hi, hOPE SOME ONE CAN HELP HERE, i am getting a Noise when pressing the clutch pedel? Im not sure if its the Bearing or some thing more serious.Thanks. Quote Link to comment Share on other sites More sharing options...
Trevor Posted August 12, 2022 Share Posted August 12, 2022 It could be one of two things 1. Worn release bearing running onto the cover plate (usually associated with someone resting their foot on the clutch pedal) 2. Worn and defective dual mass flywheel which should rattle heavily when the engine is switched off if its worn Quote Link to comment Share on other sites More sharing options...
Recommended Posts
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
