Should I use the Cig or USB outlet to charge my 2017 Nokia TA-1024 phone? Not sure if 12V is too much. Thanks.
If its running through a proper Cigar Lighter adapter then it will be fine, USB will also work but see your apprehension with using higher voltage, but its also about the current being correct, Cigar Lighter adapter will charge your phone quicker I believe
  • 4 months later...
