Brake probs
M1 hrv buzzing and clicking felt through brake pedal when car is almost stopped have had new pads fitted 3 maths ago  any suggestions pls
Sounds like the ABS is invoking when moving slow.
Check the reluctor rings (toothed wheel) on the end of the driveshafts for build up of debris or grease.
Also, check the tyre sizes are the same and inflation is correct
Beyond that I would check the sensors for resistance with a multimeter and look for any damage to them and the cables leading to the sensors
