Day Running Lights CRV 2018 UK model
Hi All
I'm confused.
Honda and the Handbook says this model a 2017 reg on a 2018 model (petrol) should have DLR lights on.
The fuse is OK, being no. 10 on drivers Footwell.
The front 'strip'lights under the dipped beam only come on with the side lights.
Our light stalk has only side light and headlight options, NO Auto.
There are no lights on 'all the time' on the front of the vehicle when driven, which is my outstanding of day time running lights which I assume us like the Volvos back in the 1980s.
So questions are
Is my understanding of DLRs correct? - Honda says yes?
do you have lights on all the time on the same model?
do you know of issues?
Many thanks in advance All!
Ours is a 2018 registered 1.6 SR so similar model to yours I think. When I switch on the ignition, the "strip lights" come on and are bright. They go out when starting and come back on when the engine is running - same brightness. When I put the side lights on they stay on, but dim down.
Thank you for your reply.
I suspect we should be same, even the UK legislation seems to indicate this.
I've only just come back from Carshop how supplied the car who say Honda say something different, but when I contacted Honda they said it should.
Fuse is in the circuit as well which seems odd to do if it doesn't have DLRs.
Am pursuing with Honda again but would welcome some more replies
