Hi I have a Honda 2.2 diesel 2014 with 68,000 miles it needs a new clutch I am told by one Honda independent specialist that I should replace the flywheel when replacing the clutch, The dealership says it's unlikely to need replacing as they are generally fine does anyone have any experience of this?
  • 4 weeks later...
On 6/26/2023 at 5:27 PM, Trevor said:
They will try to sell you a Dual Mass Flywheel sometimes even if its not needed
Unless it is worn (e.g clunking when the engine switches off) or you think its worth is while the gearbox is off?
So many sharks about waiting to prey on the innocent.
@StavrosUnusual for the clutch to wear out so soon. Are you operating the clutch properly?
