All warning lights up can`t clear
Hi all
I have a 2017 honda civic cvt-1.8  mk9  , i recently purchased a scanner to to see if any fault codes about and if it worked with my car as my other one was no longer compatable it scanned the system recognised all the the parts and vin number , after that all my lights come on cbtc , tps , handbrake abs the lot even though there is nothing wrong with them i have tryed reset manually not haveing it , i saw on youtube there was a hard reset some how but not been able to get it to i even reset to factory defaults on infotainment system . I assume there is something im missing along the way some simple fix .
Regards
Lord
A photo of the lights would help.
Were there any lights on before you used the scanner?
Hi all
I cleared the lights yesterday  by following the scanner section for reset all sensors after a few mins and on / off ignition for the process all was restored .
