ABS SENSOR
Anyone know where I can get a replacement O/S/R ABS sensor 57470-SR2A08 ? Apparently Honda dont make them any more
I have found that using an ABS sensor from the same model of car but another corner (has to be as long if not longer) does work - e.g. O/S/R for use in N/S/R or either one of the front wheels
Also, has to be the same fitting but as the resistance is not too different (higher. lower) so it does function and then you just loop the cable so its tucked out of the way
