How can I test if my Aircon cooling is working in these winter temps? I think I need a hot day for cool air to blow through. Jazz Exec VTEC Auto 2018.
Sorry got to say it - don't you need a cool day for heat to blow through. BRAZZER RN gave me some good advice when mine wasn't working change the relay first (about a tenner off ebay) before spending loads.
Mine still isn't working because I got the relay but could find a fuse box diagram the same as mine so never used it!
Well I have now seen leakage under the car engine passenger side. Looks clear but oily. Wouls this be the Air Con. There are no warnings and the car drives OK. Honda wanted £350 a while back because they have to remove a lot of bits to get at it. Advice welcome.
If the a/c isn't working your windoews will steam up in cold weather. AC units drip condensation, the oiliness may be being collected from elsewhere as it drips?
  • 6 months later...
I have now learned from MOT by Honda that there is a gas leak and the cooler may need changing. They have quoted £500 to repair with a non approved (Honda) unit. Anyone had this done by a non Honda dealer?
