Hello, does anyone have a first generation CR-V with the 126bhp engine and automatic gearbox? If so, what speed is your engine doing at 60mph (level road, steady speed)? I think my transmission, or somethin else, is slipping slightly, because the engine is doing about 3000rpms and stays there, and I thought it should be closer to 2500-2600rpms. Any advice would be much appreciated. There don't appear to be any other issues with the gearbox. It is selecting gears without any issues and the change is about as smooth as any other 4 speed automatic gearbox from that era.
  • 4 weeks later...
Not yet, although it is on the to do list. Lack of time is a factor. Though the transmission is changing gears smoothly and there is no clonking when engaging gears. When I eventually get round to changing the fluid I will put an update up. The fluid itself does not look too bad. It is not new, I can tell that much, but not too bad. Is the filter actually a serviceable item on these transmissions, or can you only access it when you are rebuilding the gearbox?
