Hi Good evening,
would like some advice please...
so few weeks ago changing gear was getting harder and harder and was grinding gears so took it into a garage who replaced the clutch master cylinder said it was leaking and had no fluid in biting point is really low to the ground but no clutch slippage.
2 weeks on biting point is still pretty low to the floor and sometimes still grinds putting it into a gear its much better than it was but still occasional, also the gear lever in general feels like it could go in and out of gears a bit easier not the smoothest ... anyone any ideas??  does it need a clutch adjustment or gearbox oil change?
kind regards
I would say that is could be a bit of air in the clutch hydraulic system which could do with another bleed.
It also wouldn't do any harm to change (or at least check the level) the gearbox oil....to at least eliminate that possibility
Just abit of an update garage said the clutch master cylinder was leaking so had that changed which was better for a week then started crunching gears again after a week or 2 so garage had it back said the slave cylinder was now leaking so changed that much better at the moment but 2nd gear seems to crunch every so often they also said the clutch was showing signs of wear and tear could this be our 2nd gears issues? It mainly does it coming down the gears into 2nd
Thanks for any help
I would start by checking the gearbox oil and see if there is enough in there and maybe consider replacing the oil?
Another way to avoid the crunching is the using the old method known as double declutching. Or even a slight blip on the throttle on downshifting can also work to eliminate the gear crunching
  • 4 weeks later...
Bit of an update just got back from mr clutch there was air in the system from when the other garage changed the master and slave cylinders, they also said clutch was not worn like we got told wont be using them again happy with mr clutch drives good now shakes abit at idle think it could be spark plugs will have to look into those
