honda1 Posted January 26 Posted January 26 Hi Good evening, would like some advice please... so few weeks ago changing gear was getting harder and harder and was grinding gears so took it into a garage who replaced the clutch master cylinder said it was leaking and had no fluid in biting point is really low to the ground but no clutch slippage. 2 weeks on biting point is still pretty low to the floor and sometimes still grinds putting it into a gear its much better than it was but still occasional, also the gear lever in general feels like it could go in and out of gears a bit easier not the smoothest ... anyone any ideas?? does it need a clutch adjustment or gearbox oil change? kind regards
Trevor Posted January 28 Posted January 28 I would say that is could be a bit of air in the clutch hydraulic system which could do with another bleed. It also wouldn't do any harm to change (or at least check the level) the gearbox oil....to at least eliminate that possibility 1
Register a new accountSign in
