Hi, my vehicle is suffering rear inner edge tyre wear. I am aware there is some adjustment that can be made on the lower arms, my question is - is there any adjustment that can be made to rear wheel alignment. I believe that the 'adjustment ' nut impacts on the rear camber and is adjustable for each wheel.
Anyone can provide some more information on the subject or point me in the right direction ?
My vehicle has clocked up 145k miles and has always been a bit heavy on rear tyres, even after 4 wheel alignment at a reputable garage chain, in fact on that occasion an adjustment was made but insufficient adjustment to be within tolerance. The cars history is known and no accident damage that could account for my problem. BTW the car drives fine and handles well in any weather, its just I fancy having a go at getting it to be more gentle on tyres.
Thanks Chris.
  • 1 month later...
To clarify..... there is a 10 point nut on the rear lower arm, this provides adjustment for the rear Toe. Ive found the specs and on one occasion , during 4 wheel alignment it was adjusted.
Can anyone provide any further information about the process, socket size etc. Direction of nut rotation vs toe in or out as I hope to be able to make this adjustment myself. Most other Honda's appear to have 3 bolts securing said arm.
Thanks
I adjusted the rear arms many years ago but were tough to loosen given where they are located so some effort may bew required to free them up.
With four wheel alignment on this setup it is important to check and adjust from the rear first as a lot of operators adjust the front to compensate for the rear readings which is not what you are looking to do
Register a new account
Sign in
