1998 Civic Aerodeck 1800 VTI
Hi guys, newbie here, had plenty of 1999-2001 civics enjoying the windows dropping, steering column loom failing and the CV boot’s costly repairs. However, rude as you like, seeking advice on an Aerodeck that has been in the family from new. Can’t get any proper info on these so wondered if I could get a link or two from the group on their history. I know they are quite rare now and dare I ask how much they are worth? Many thanks, Paul
Hi....welcome to the Club
There are still a few Aerodecks around but not many on the road.
Spare parts especially panels are becoming harder to source but mechanically they are usually reliable as were most of the early models.
  • 3 weeks later...
Hi all, does anyone have a working distributor or advice on where to buy one second hand or new as it has failed (garage diagnosed) on my sister whilst driving it
Any help would be greatly welcome, the car is worth nothing if it isn't running :(
Edited by Bakersone
I seem to recall using a module from another manufacturer to resolve the parts supply issue at the time - could have been Rover or similar manufacturer that used the same system - at least it gives you an opportunity to widen the search.
Searching by Part Numbers would be best to get straight to the correct part
Edited by Bakersone
Good and bad news then !
CV gaiter is relatively cheap and easy to sort
ABS and SRS lights - I would look for any connections under seats (for the SRS) and under the bonnet and each wheel (for the ABS).
I believe there is a limited OBD interaction that you can read codes for engine but not sure that it goes deep enough for SRS and ABS.
Sometimes it is a common factor such as poor connections on the battery or earth connections to the chassis
They used to sell CV gaiters that were split and you placed them over the CV joint and ran glue along the length to secure it along with the clips each end.
They sort of worked but were a little bit rigid so would pull off the joint but at least they lasted long enough for an MOT test :-)
