Preventative Maintenance
My CRV MK3 2.2 DTEC has done 150000 miles. It has original clutch, water pump, turbo etc and a full Honda main dealer service history. I want to keep this car as long as possible.
Which preventative part replacements should I consider doing to get another 100000 miles out of the car?
Hi John
The most crucial parts to consider changing as a maintenance task are the air filter, oil filter, cabin filter and also the fuel filter (which is a bit of a fiddle to change but quite straightforwards.
In addition to these service parts I would advise to change the rear diff oil with the correct fluid from Honda as this can manifest as clunking when turning in on a sharp corner (e.g pulling into a driveway) which tells you the fluid needs replacing.
Beyond that, the 3rd generation CR-V is a superb vehicle and there is no reason it shouldn't go on for many years ahead.
Thanks Trevor
Should I consider replacing components like the water pump and turbo before they fail as their failure can cause consequential damage ?
Edited by John Marston
I'm not aware that these components would in fact fail due to inherent faults and are not necessarily maintenance items.
The turbocharger is best maintained by ensuring the air filter is in good condition and also the engine oil is of the correct grade and quality.
