Definitely a rare one to see on the roads nowadays - feel free to post an advert in the forums to see if you get some interest from any members. Maybe post up some pics of the Civic and some more info to assist with selling it.
Weird beeping
Could be faulty parking brake switch.
The indicated mileage is based on your last driving habit along with external and internal temperature together with battery temperature. Is A.C on, heater fan, seat heats, radio, phone charger switched on, etc. etc.?
Heater motor fan inop.
HAPPY NEW YEAR...
- Christmas
- DRL Jazz 2014 v-tec.
- The old girl!!
