i have had my 2001 honda civic 1.7 coupe since 2016 previous owner from new was a family member. the car has done 63500 miles with history. fully maintained. this car is now a rare site on our roads. as i am now getting on in years i am looking for a dedicated honda lover to take it of my hands and take care of it.
Heater motor fan inop.
HAPPY NEW YEAR...
Hi fellow members any ideas!?
- Christmas
- DRL Jazz 2014 v-tec.
- The old girl!!
Must have missed this , nearly a year ago!! What do you use
