HAPPY NEW YEAR...
Heater motor fan inop.
Hi, my heater blower stopped working, but new ones are expensive, did the 05/06 civic blower heater work for you and the connectors are same ? i have an FRV 2.2 CDi RHD
Hi fellow members any ideas!?
- Christmas
- DRL Jazz 2014 v-tec.
- The old girl!!
