  2. Best thing is to see what the part number is (possibly label or sticker on the motor) and cross-reference to Civic motor on eBay
  3. We couldn't afford to waste good(?) beer by spraying it up the walls - you were obviously a wealthy person in the '70s :-)
  4. Last week
  5. Earlier
  6. Alan gsd posted a topic in The Lounge
  7. Most vehicles nowadays have the facility to retrofit accessories and most of it is in place from the factory (as in wiring loom, fuses, etc). If they car was taken to the dealer for retrofitting lights, etc then it is a case of fitting the lights, putting power to the lights (fuse, switches, etc) and then programming it into the CanBus system to activate it.
  8. Hi all, admins delete if inappropriate, either way thankyou for your help and advice. Up for grabs here: 1998 Honda Civic Aerodeck 1.8 Vti for sale | eBay
  9. Thanks again for your advice
  10. I would be tempted to top it up and see if that changes the reading and especially when it gets down to this level again
  11. I'm selling my Honda FR-V due to moving abroad. It's been well maintained and has a new MOT and full service history. PIctures won't upload here because they're too large, see advert on Gumtree. Located in NW London. Please PM if interested.
  12. Loved the adverts of the era as they were memorable - even after 50 years I can still sing the song that was played or the taste of the drink, etc.
  13. Hi Ivan....welcome to the Club I'm sure you will be pleased with the Jazz and its reliability and build quality Good to have you onboard!
  14. I have found water drips from the air pressure vent ending up on the floor also. Have new one ready to replace and seal in! This is a 2017 CRV. Should add that I have been a CRV driver since 2005 and this is the first one to show a waterleak.
  15. Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? Thanks
  16. Any upgrade in bulbs is good in my opinion. Whether they bring a noticeable difference to the table may be good but unlikely to be any worse than the standard halogen bulbs
  17. Maybe worth increasing the pressures by a couple of psi to see if this extinguishes the warning. You can always let out some air but also good to check you don't have a slight leak on one of the tyres. Resetting the pressure settings on the vehicle may just be masking a fault in one of the tyres Also, ensure you check the tyres when cold
  18. Steve replied to Alan gsd's topic in The Lounge
    I used to love Jasper
  19. That appears to be the earlier version with single oxygen sensor that only measures earlier Euro standards emissions. The later version which is on the car measure both pre and post catalytic converter oxygen levels to compare and adjust feeling to optimise and measure the efficiency of the cat.
  20. Hi @Maurice j I have attached a PDF for you to look over to do some checks for your locking issue. Honda_eNy1_WalkAway_Lock_Troubleshooting.pdf
  21. Steve replied to Alan gsd's topic in The Lounge
  22. 8520jason replied to tonydee's topic in 1984 to 1992 CRX
  23. Must have missed this , nearly a year ago!! What do you use
  24. Hi Wuzhee, I have fitted replacement upper arms and adjusted them. On checking rear wheel toe, the nearside was showing it was toeing in. Worked out the 10 point nut has nothing to do with toe, its adjusted by slackening locking nut, item 1, then adjusting via item 2. Item 3 is an offset washer and fixed plate, by turning item 2 the offset washers contact with fixed plate 'moves' the arm. I setup a DTI and adjusting item 2 by approx 10minutes (on a clock face) I achieved 0.2mm change to the toe, where I was measuring it. I rechecked both rear wheel toe's and are now at a setting more in keeping where it should be, i.e. slight toe-in. For info turning item 2, near side arm, makes the wheel toe more in an outward direction measuring from the center point of the wheel facing forward and measuring off tyre wall. Im aware tyre walls are inconsistent in their shape however as the wheel was locked and the DTI remained fixed then a true reading was achieved. Thanks to everyone for their assistance to me.
  25. I would imagine it would last a great deal longer if the fluid and filter were changed in the transmission which quite often is neglected from service and maintenance routines
