Water in the spare wheel well.
For some unknown reason I appear to be collecting water in my spare wheel well. The mats above are not damp and the seals look good. Has an had something similar, what is the solution?
Towbar fitting - messy bumper
I hope you didn't pay full price for that awful job. You could make a blank and paint it with a complimentary colour. A local independent paint sprayer could give good advice.
Dim low beam
I changed them with exeon H11. It is better and not too bright for other drivers.
Definitely a rare one to see on the roads nowadays - feel free to post an advert in the forums to see if you get some interest from any members. Maybe post up some pics of the Civic and some more info to assist with selling it.
Weird beeping
Could be faulty parking brake switch.
The indicated mileage is based on your last driving habit along with external and internal temperature together with battery temperature. Is A.C on, heater fan, seat heats, radio, phone charger switched on, etc. etc.?
Heater motor fan inop.
HAPPY NEW YEAR...
- Christmas
- DRL Jazz 2014 v-tec.
Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? Thanks- Tyre pressure monitor on 2013 Honda civic es i-vtec 1.8.
