FRV Heater Fan Blower replacement
Hi i am trying to remove the screws which holds the fan blow, first 2 screws are easy to access, however, the third screw is difficult to get to, has any replace fan blower on FRV or has any tips on how to reach the third screw? Thanks
Water in the spare wheel well.
eBay link to a Smoke Generator: Smoke Generator
Dim low beam
Thats good to know as a recommendation for others, thanks!
Back in 1971
That looks in great condition and worth the price for sure.
Towbar fitting - messy bumper
I hope you didn't pay full price for that awful job. You could make a blank and paint it with a complimentary colour. A local independent paint sprayer could give good advice.
Weird beeping
Could be faulty parking brake switch.
The indicated mileage is based on your last driving habit along with external and internal temperature together with battery temperature. Is A.C on, heater fan, seat heats, radio, phone charger switched on, etc. etc.?
Heater motor fan inop.
HAPPY NEW YEAR...
- Christmas
- DRL Jazz 2014 v-tec.
Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? Thanks- Tyre pressure monitor on 2013 Honda civic es i-vtec 1.8.
