Dishonesty or Not???
- The old girl!!
Hi Tonydee, I believe there is no Haynes manual for the CRX, however, there maybe a Clymer in the USA? other than that, I also have a PDF genuine Honda CRX workshop manual, if that's any good.- 1998 Civic Aerodeck 1800 VTI
Hi guys, newbie here, had plenty of 1999-2001 civics enjoying the windows dropping, steering column loom failing and the CV boot’s costly repairs. However, rude as you like, seeking advice on an Aerodeck that has been in the family from new. Can’t get any proper info on these so wondered if I could get a link or two from the group on their history. I know they are quite rare now and dare I ask how much they are worth? Many thanks, Paul- Headlamps
- Rear Wheel Alignment FRV
- FREE RADIO CODES
Hi Artur, have you still got the jade and need parts? Brian- Honda Jade Replacement windscreen
I can supply these custom made for a negotiable price if I have 1 or 2 more buyers. impossible to get in europe. not stocked OEM: 73111T4R003- Honda Jade Replacement windscreen
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
