	Walk away auto lock function not workingYerman replied to Maurice j's topic in Honda e / Honda e:Ny1 Vehicle does not lock after walking away following option of right button. What page is it indicated otherwise? Ian
	porgu joined the community
	IanG joined the community
	PC25 joined the community
