	clive joined the community
	61Clank joined the community
	NWales joined the community
	Walk away auto lock function not workingYerman replied to Maurice j's topic in Honda e / Honda e:Ny1 Vehicle does not lock after walking away following option of right button. What page is it indicated otherwise? Ian
	porgu joined the community
	IanG joined the community
