  2. It's has done well for 20 years so a hole about the size of a pin head is good going, so think my spot of glue will do the job for now.
  3. Well I suppose its done well over all these years but they can get a bit thin over time with all the shifting back and forwards. I replaced one on a 3rd generation CR-V and it was very easy to pull the trim off and attach the new gaiter but kept pulling out as the material was too thick and rigid
  4. Yesterday
  5. Well it does seem you have to remove a far bit of trim to access the gator so I've used a small spot of glue to mend the very small hole and it looks OK. I do love my Honda but unlike my Ford Transit where you could get to things with ease. Honda's are so well made it's a task to do anything I'm happy to say!!
  6. Last week
  7. Earlier
  8. Afternoon, is it easy to replace the gear shift gator on a 2005 CRV, fingers crossed I don't need to remove all the dash etc!! Alan
  9. If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you
  10. I think if they are original roof rails and they are now 19 years old and I would therefore place as little weight on them as possible to be on the safe side
  11. https://en.wikipedia.org/wiki/Honda_CR-V
  12. Hello there I have a 2006 Honda FR-V Sport (2.0L petrol) with original Honda roof bars (but not the later roof rails). The manual doesn't specify the safe dynamic roof load limit for the vehicle unfortunately. Searches online coming up with wildly different figures in the range of 50Kg-75Kg-100Kg. Does anyone know where I can find this information as despite searching, im still none the wiser. Many thanks Duncan
  13. that's a brilliant ad and wished other manufacturers could do something this ingenious - now they just focus on the lifestyle aspect and forget its even a car.
  14. I've not had much luck buying from China via Ebay lost a few ££££££ so wouldn't chance it unless you can afford to take a chance.
  15. Just read this , my frv radio is rubbish, I've read somewhere that the earth to the aerial is very poor on frv. However... I've noticed on a Chinese selling express site there offering bezels that allow the fitting of a double din radio into the opening in the dash, when I started looking honda did them for around £150 ! However years on and that Chinese site sells something for a few quid. I haven't bought one or know anyone who has but a few quid is worth a bet if it solved it for you. I did read somewhere ( maybe here) an easier removal process for the radio rather than prolonged strip out required. Hope that helps. Chris
  20. Did either of you (or anyone else) solve this problem? Mine has started doing the same... thanks.
  23. Alan gsd
  24. These Mk 3 Jazz's are a bit posh tyre senors, remember the good old days when every garage air line gave a different reading!!. Had a damged tyre valve yeras ago was a late at night broken at the base used superglue got me home!!!!
  25. The same as when driving, tyre pressures increase on their own in hot weather. I don't know if the tyre pressure alarm points can be altered in the car to allow for the extra pressure in the tyres ( I'm not overly familiar with the Jazz as it's my wifes), but if not then you could physically lower the tyre pressures by a couple of lbs to stop the alarm showing. Don't forget to increase the pressures when the weather cools down. There should be enough leeway in the settings to allow for some variation in pressures.
