  2. If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you
  3. Yesterday
  4. Last week
  5. I think if they are original roof rails and they are now 19 years old and I would therefore place as little weight on them as possible to be on the safe side
  6. Earlier
  7. https://en.wikipedia.org/wiki/Honda_CR-V
  8. Hello there I have a 2006 Honda FR-V Sport (2.0L petrol) with original Honda roof bars (but not the later roof rails). The manual doesn't specify the safe dynamic roof load limit for the vehicle unfortunately. Searches online coming up with wildly different figures in the range of 50Kg-75Kg-100Kg. Does anyone know where I can find this information as despite searching, im still none the wiser. Many thanks Duncan
  9. that's a brilliant ad and wished other manufacturers could do something this ingenious - now they just focus on the lifestyle aspect and forget its even a car.
  10. I've not had much luck buying from China via Ebay lost a few ££££££ so wouldn't chance it unless you can afford to take a chance.
  11. Just read this , my frv radio is rubbish, I've read somewhere that the earth to the aerial is very poor on frv. However... I've noticed on a Chinese selling express site there offering bezels that allow the fitting of a double din radio into the opening in the dash, when I started looking honda did them for around £150 ! However years on and that Chinese site sells something for a few quid. I haven't bought one or know anyone who has but a few quid is worth a bet if it solved it for you. I did read somewhere ( maybe here) an easier removal process for the radio rather than prolonged strip out required. Hope that helps. Chris
  12. Hi all my 2009 Frv reversing unit failed so I bought a cheap no make system, drilled out existing sensors and fitted new sensors and wires it in, a wire to reversing light and wires to the beeper ( fixed next to existing sounder). I think I got the 'kit' for under £15.00 and apart from a little faffing around its been working for the last few years. I didn't have the equipment to check the original control unit or each individual ultrasonic sensor so it seemed to logical cheap fix.
  13. Hi Artur, have you still got the jade and need parts? Brian
  14. I can supply these custom made for a negotiable price if I have 1 or 2 more buyers. impossible to get in europe. not stocked OEM: 73111T4R003
  15. Hi, Desperately looking for a replacement front windscreen. The only 2 breaker jades in country don't have one intact. c.2K from japan!!! 6 month lead time. Have found someone in UK who can make a minimum of 5 of them but would need a couple of other buyers to justify. OEM: 73111T4R003 Maybe someone knows of an unlisted broken Jade somewhere? as I can have a guy who can remove the glass safely. any help appreciated. or am looking at a write off. Brian.
  16. Did either of you (or anyone else) solve this problem? Mine has started doing the same... thanks.
  17. things seemed so much easier back in the day - as long as the tyre was round then it was fine 🙂
  18. I think some of them are making a revival - at least in name though Lost too many good brewerys over the years (Ringwood Brewery my local one has now closed) :-(
  19. Alan gsd
  20. These Mk 3 Jazz's are a bit posh tyre senors, remember the good old days when every garage air line gave a different reading!!. Had a damged tyre valve yeras ago was a late at night broken at the base used superglue got me home!!!!
  21. The same as when driving, tyre pressures increase on their own in hot weather. I don't know if the tyre pressure alarm points can be altered in the car to allow for the extra pressure in the tyres ( I'm not overly familiar with the Jazz as it's my wifes), but if not then you could physically lower the tyre pressures by a couple of lbs to stop the alarm showing. Don't forget to increase the pressures when the weather cools down. There should be enough leeway in the settings to allow for some variation in pressures.
  22. My Mk 3 Jazz tyre pressure sensors have been activated frequently in the recent hot weather . A bit of a nuisance . Any suggestions please ?
  23. It should fit the apeture but Halfords stock kits to ensure the wiring and fascia are suitable
  24. I agree with you Alan, it was by far the best of all the generations so far
