  2. Hi thanks for the info esp tracking rear first.
  3. I adjusted the rear arms many years ago but were tough to loosen given where they are located so some effort may bew required to free them up. With four wheel alignment on this setup it is important to check and adjust from the rear first as a lot of operators adjust the front to compensate for the rear readings which is not what you are looking to do
  4. I would imagine it would last a great deal longer if the fluid and filter were changed in the transmission which quite often is neglected from service and maintenance routines
  5. definitely the wisest and cheapest repair
  6. a fine car throughout the years and the different generations of the CR-V
  7. Vehicle does not lock after walking away following option of right button. What page is it indicated otherwise? Ian
  8. Hi...welcome to the Club Fantastic car to own - haven't seen one on the road in years. Good to have you onboard
  9. The alternator will be engine ecu controlled also i think.
  10. It now needs the live data looking at. Just because its had an alternator and battery doesn't mean its necessarily charging. id be starting there first
  11. To clarify..... there is a 10 point nut on the rear lower arm, this provides adjustment for the rear Toe. Ive found the specs and on one occasion , during 4 wheel alignment it was adjusted. Can anyone provide any further information about the process, socket size etc. Direction of nut rotation vs toe in or out as I hope to be able to make this adjustment myself. Most other Honda's appear to have 3 bolts securing said arm. Thanks
  12. Hi. yes everything else works fine and fuses checked by myself and garage, its just those mentioned but it all started when the alternator went kaput and lit the dash up like a xmas tree. Yes, the car was told it had a new battery. i have disconnected the black wire on the battery many times, removed the negative cable from the battery many times. Tried the leave ignition on without running for 10 mins, cycle ignition thing 5-6 times without starting. The garage i took it too showed me the computer readout and it was green for everything. No faults showed up at all
  13. Do your interior lights come on when you open the doors? Have all the fuses been checked? It really needs to go onto a live data session to see what inputs the BCM is seeing. From what you've said it sounds like a problem with the BCM. You havent mentioned if that a reset had been done when the battery was changed. Also the battery management system might need a reset also. Could be why the stop/start isn't working. anybody with half a brain would be close to finding the problem on live data.
  14. Earlier
  15. Why has all the above been changed? Who has changed them? They're stabbing in the dark, mate.
  16. @OLSTERMEISTER civic dtec 1.6. new battery new alternator new battery sensor auto stop start still not working. car has been told it has a new battery. also almost around same time folding mirrors, electric windows and alarm wont work fob has new battery tried all the reset procedures for all the above issues. im almost a grand in on both problems and no one can fix it. any ideas?
  17. My Eny1 is 18 months old and done 4300 miles The Honda on line brochure clearly states that when the right hand boot button is pressed the boot will close when you walk away and lock the boot and car The boot closes and locks but there car stays unlocked The Honda garage tell me that only the boot should lock and Honda Tech support confirm this HELP Does anyone else have this problem? Maurice
  18. Hi all. thanks for the in. i have Civic 1.6 Dtec. Love the car hate the gremlins. auto stop start issues are killing me. £600 down with new alternator, new battery and now new battery sensor and it still isnt working properly. Very intermittent but mostly not working. car has been on OBD and there are no faults showing. Car has been told it has a new battery. Can anyone throw some light on this?
  19. Hi all, I have just inherited a 1981 Honda Civic Hondamatic 3dr in Shetland White with a blue interior. My grandad bought it new, grandmother took it on when he passed now left to me following her passing. Looking to get it back on the road properly following a video made by The Brake Show. Any help/advice/parts is greatly appreciated. Thanks, Sean
  20. OK, so mine's done 113k, what's the highest on here?
  21. Evening all We all know these cars are incredibly reliable, but I suspect the weak link is the auto box. Anyone any idea as the the expected life expectancy, assuming scheduled fluid changes, no towing (not that I expect many people would try to tow anything given the limitations of the petrol/auto combination...) etc? Thanks, Rob
  22. Hi, my vehicle is suffering rear inner edge tyre wear. I am aware there is some adjustment that can be made on the lower arms, my question is - is there any adjustment that can be made to rear wheel alignment. I believe that the 'adjustment ' nut impacts on the rear camber and is adjustable for each wheel. Anyone can provide some more information on the subject or point me in the right direction ? My vehicle has clocked up 145k miles and has always been a bit heavy on rear tyres, even after 4 wheel alignment at a reputable garage chain, in fact on that occasion an adjustment was made but insufficient adjustment to be within tolerance. The cars history is known and no accident damage that could account for my problem. BTW the car drives fine and handles well in any weather, its just I fancy having a go at getting it to be more gentle on tyres. Thanks Chris.
  23. It's has done well for 20 years so a hole about the size of a pin head is good going, so think my spot of glue will do the job for now.
  24. Well I suppose its done well over all these years but they can get a bit thin over time with all the shifting back and forwards. I replaced one on a 3rd generation CR-V and it was very easy to pull the trim off and attach the new gaiter but kept pulling out as the material was too thick and rigid
  25. Well it does seem you have to remove a far bit of trim to access the gator so I've used a small spot of glue to mend the very small hole and it looks OK. I do love my Honda but unlike my Ford Transit where you could get to things with ease. Honda's are so well made it's a task to do anything I'm happy to say!!
