  2. OK, so mine's done 113k, what's the highest on here?
  3. Earlier
  4. Evening all We all know these cars are incredibly reliable, but I suspect the weak link is the auto box. Anyone any idea as the the expected life expectancy, assuming scheduled fluid changes, no towing (not that I expect many people would try to tow anything given the limitations of the petrol/auto combination...) etc? Thanks, Rob
  5. Hi, my vehicle is suffering rear inner edge tyre wear. I am aware there is some adjustment that can be made on the lower arms, my question is - is there any adjustment that can be made to rear wheel alignment. I believe that the 'adjustment ' nut impacts on the rear camber and is adjustable for each wheel. Anyone can provide some more information on the subject or point me in the right direction ? My vehicle has clocked up 145k miles and has always been a bit heavy on rear tyres, even after 4 wheel alignment at a reputable garage chain, in fact on that occasion an adjustment was made but insufficient adjustment to be within tolerance. The cars history is known and no accident damage that could account for my problem. BTW the car drives fine and handles well in any weather, its just I fancy having a go at getting it to be more gentle on tyres. Thanks Chris.
  6. It's has done well for 20 years so a hole about the size of a pin head is good going, so think my spot of glue will do the job for now.
  7. Well I suppose its done well over all these years but they can get a bit thin over time with all the shifting back and forwards. I replaced one on a 3rd generation CR-V and it was very easy to pull the trim off and attach the new gaiter but kept pulling out as the material was too thick and rigid
  8. Well it does seem you have to remove a far bit of trim to access the gator so I've used a small spot of glue to mend the very small hole and it looks OK. I do love my Honda but unlike my Ford Transit where you could get to things with ease. Honda's are so well made it's a task to do anything I'm happy to say!!
  9. Afternoon, is it easy to replace the gear shift gator on a 2005 CRV, fingers crossed I don't need to remove all the dash etc!! Alan
  10. If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you
  11. I think if they are original roof rails and they are now 19 years old and I would therefore place as little weight on them as possible to be on the safe side
  12. https://en.wikipedia.org/wiki/Honda_CR-V
  13. Hello there I have a 2006 Honda FR-V Sport (2.0L petrol) with original Honda roof bars (but not the later roof rails). The manual doesn't specify the safe dynamic roof load limit for the vehicle unfortunately. Searches online coming up with wildly different figures in the range of 50Kg-75Kg-100Kg. Does anyone know where I can find this information as despite searching, im still none the wiser. Many thanks Duncan
  16. Just read this , my frv radio is rubbish, I've read somewhere that the earth to the aerial is very poor on frv. However... I've noticed on a Chinese selling express site there offering bezels that allow the fitting of a double din radio into the opening in the dash, when I started looking honda did them for around £150 ! However years on and that Chinese site sells something for a few quid. I haven't bought one or know anyone who has but a few quid is worth a bet if it solved it for you. I did read somewhere ( maybe here) an easier removal process for the radio rather than prolonged strip out required. Hope that helps. Chris
  17. Hi all my 2009 Frv reversing unit failed so I bought a cheap no make system, drilled out existing sensors and fitted new sensors and wires it in, a wire to reversing light and wires to the beeper ( fixed next to existing sounder). I think I got the 'kit' for under £15.00 and apart from a little faffing around its been working for the last few years. I didn't have the equipment to check the original control unit or each individual ultrasonic sensor so it seemed to logical cheap fix.
  18. Hi Artur, have you still got the jade and need parts? Brian
  19. I can supply these custom made for a negotiable price if I have 1 or 2 more buyers. impossible to get in europe. not stocked OEM: 73111T4R003
  20. Hi, Desperately looking for a replacement front windscreen. The only 2 breaker jades in country don't have one intact. c.2K from japan!!! 6 month lead time. Have found someone in UK who can make a minimum of 5 of them but would need a couple of other buyers to justify. OEM: 73111T4R003 Maybe someone knows of an unlisted broken Jade somewhere? as I can have a guy who can remove the glass safely. any help appreciated. or am looking at a write off. Brian.
  21. Did either of you (or anyone else) solve this problem? Mine has started doing the same... thanks.
  22. things seemed so much easier back in the day - as long as the tyre was round then it was fine 🙂
  23. I think some of them are making a revival - at least in name though Lost too many good brewerys over the years (Ringwood Brewery my local one has now closed) :-(
