Pompey Andy
  1. Just wondered if anyone knew if the US rear wiper motors are the same as the UK. The reason I'm asking is that a new one from the US on Amazon is £70, about the same price as a secondhand one in the UK.
  2. Not a wheel bearing is it.
  3. DA, I think Honda must have fixed the issue with the clock as mine is working fine now.
  4. This issue has been fixed by Honda, my clock is working fine again now.
  5. Hi Trevor it was the fuel filter.
  6. Yes mine is working as well 😃
  7. I had the same issue with my CRV, it was an issue with the Honda satellite system, not the one in the car but the one orbiting the earth. But last week it was fixed and my clock is now working correctly.
  8. Evening All. Just a qq any one had issues with their High Pressure Fuel Pump on the 2.2 diesel engine, I have had two instances where the engine management light has come on in the last two weeks and had fault code P0087 which means low fuel pressure. Two years ago I was getting the same issue but the garage put new firmware on and it seemed to fix it, but i think that may have just been a coincidence as the issue is back. Sometimes it will stop the car other times it just goes in to limp mode. You can start the car no problem after the event, the fault stays for 4 more engine on and off, then disappears. It's very frustrating. I have been recommended a diesel specialist in Portsmouth that will test the whole system so may try that. The sensor is within the pump and the whole unit is between £500 and £700 so not cheap. Cheers Andy
  9. Hi Nige I had a 2010 Accord 2.2 from 90K till 257K with most only normal wear and tear items. It was mostly 130 mile daily trip up and down the A3 and was returning between 45 and 49 mpg . The front shocks go around 120K as that is a heavy lump in the front. They were recalled as the manifolds leaked but that would be in the history. But other than that no problem with mine.
  10. oh that was a good night for me Trev working at the Data Centre, treble time and a day in lieu just in case it went wrong 😆
  11. Yes there is a topic running on another page, at least 10 others complaining, 10.07 everytime I turn the car on.
  12. Mine is 10.07 everytime I turn the car on, I thought we would all be the same time but it appears not, I was hoping we would be able to start a 10.07 club 🙂
  13. Great thanks for the update, I think i could live with it if the clock wasn't so large when the SatNav isn't on. I guess I'll need to have the radio display on 🙂
  14. Battery seems ok and is only about 3 years old.
