Mark59
  1. I have put a spring assister on both sides of my rear suspension to help stop the bouncing when towing our caravan. It has helped a little but what I want to know is can I add another set to stiffen it more and hopefully cure the problem even though it will be quite stiff when not towing. Thanks for your help. I have a 2007 crv front wheel drive.
  2. Thank both for the replies.
  3. Please can someone let me know what oil I should put in my car. I have heard that 5w30 is the right one but I dont know if that is semi synthetic or fully synthetic. Thanks in advance.
  4. Mark59 replied to Mark59's topic in CR-V 2007 to 2011
    Having towed the van now the inserts work well. There is still a bit of movement up and down but it is far better than it was. Thank you again for the advice.
  5. I have had this problem and it was the clutch pedal servo. I had it replaced and it now feels like it should do and with no creaks.
  6. Mark59 replied to Mark59's topic in CR-V 2007 to 2011
    The inserts were easy to fit with a bit of silicon spray we just need a holiday to see how it is with the van attached.
  7. Mark59 replied to Mark59's topic in CR-V 2007 to 2011
    Thank you all for you help. I was getting worried we had another problem with the car.
  8. Mark59 posted a topic in CR-V 2007 to 2011
    Hi all sorry to ask another question but we have a leak under the car every time we use the fan in the car on air con or not and there is a pool of liquid under the car when we have parked up. I have checked all the fluids that I can and taken the car to the garage but he cant see anything. I thought it might be a leaking air con but it also happens with just the blower on. Thank you again for any advice.
  9. Mark59 replied to Mark59's topic in CR-V 2007 to 2011
    I have ordered some inserts so will let you know how it goes when I have fitted them. Thanks again for the advice.
  10. Hi all. Please can anyone tell me the gap of the rear coil springs as we want to fit some inserts to make the rear firmer when towing. Thank you.
  11. Mark59 replied to Mark59's topic in CR-V 2007 to 2011
    Thank you for that. I will have a look and see what would work.
  12. Mark59 posted a topic in CR-V 2007 to 2011
    Hi all. We have a Honda crv 2007 2.2 diesel car and also a caravan. When we are towing the caravan the rear suspension feels soft even though I am within towing weights. Is there a way I can stiffen the suspension without it costing a fortune. Thanks in advance.
  13. Hi Ben I had the same problem so pulled out the Bluetooth connector. I dont use the Bluetooth so will not be replacing it. Its a lot of money to replace it.
  14. I had a similar problem with my crv and the problem was caused by the Bluetooth unit draining the battery. I dont know if it is that but it might be worth looking on you tube to see where it is.
  15. All seems to be working OK now. I dont have Bluetooth but I didnt use it anyway but the car starts first time now so problem sorted. Thank you all again for your help.
