Any ideas
When I start my Honda Accord 2.4 [05 plate] the following warning lights permanently stay on ; (1) ABS, (2) VSA Activation & (3) VSA System
It was the N/S/R sensor which was luckily easy to replace and solved this issue and then I just needed a diagnostics machine to reset the VSA. Thanks for the advice
A local garage provided the assistance of their diagnostics machine to reset the VSA (obviously for a small fee)
  • 8 months later...
Hi, anyone experienced an ABS motor relay :open circuit fault  , ABS and VSA light stay on and sometimes goes off , ABS /VSA light goes on after some kms running and after starting engine again, checked the ABS relay ,the motor -everything is fine , the only thing have to check is inside  the motor relay of the  ABS module. has any one had experienced the same issue...Thanks.
  • 4 months later...
I have the same problem vsa tsa abs light on try to delete no succes.
Now i want to check relay but wich and where is the abs relay placed .
More than likely a faulty wheel speed sensor causing this issue
Ok and how can i check them and are they just on the front wheels or on all 4 wheels
they are on all four wheels and the best method is to disconnect the connector (usually inside the boot area and under the bonnet) and measure the resistance from the sensor.
They should all be approximately the same (give or take a few ohms).
If one reading is non existent then more than likely an open circuit meaning it is defective.
Ok thanks that s answer i can do something but one thing opencircuit defective but why obd screams abspump motorrelay open circuit.
And the stupid thing is it s not continously some drive no problem then sometime while driveng this morning turning on ignition key.
And only i can get fault out while driving ans turn ignition key off for 15sec then while rolling start and then gone.
Some tomes 3 times restart.
Firts i going to check the wheel sensors.
Thank u again for answer
