Hi,
Does anyone know where the filling and drain points are for a 1.6 diesel CRV to carry out an MT fluid change? Alternatively, if you could point me in the direction of a relevant "how-to" webpage.
Thanks,
Mike
Not entirely sure but if they are not sealed for life units then I would look for the lowest point of the transmission and see what is there, with the refill being slightly higher up.
Sorry cannot offer any other solid info but good luck with it and feel free to post up the location of the plugs for future reference
Try Googling it, I had to for mine a mk3.It was only place that gave a result,when i removed the filler at 100k ,which you had to remove the air filter box and battery box to get at it.I don't think it had been out before,altho' it had been to a main dealer and is supposed to be done at 30K.The filler was on the side of the trasmition that face the front bumper,and
maybee 6cms or so above the drain.if there is no dratn as Trevor thinks you will have to get an oil pump and suck it out threw the level plug.oil pump about £10 on ebay.goodluck.
  • 3 months later...
Youtube, very small bolts, re filling is a pain
