Hi,
First time poster here.
Does anybody know how to remove the auxiliary break light from the rear hatch of the crv (2014 diesel 2.2).?
also, is it on a separate fuse?
Thanks
Stewart
It should be on the same fuse as the other brake lights.
Have you tried banging it gently to see if there is a break in the circuit, poor connection, etc.
If so and still not working then i believe you need to remove the internal trim from the tailgate to remove the unit
