Getting my car through the MOT is always is a bit of a trial.
It takes ages to get the  car engine/exhaust warm enough to pass the emissions test .
I always use super 97 fuel with Redex  and whilst the car really drives well it still takes a while to get it hot.
The car is an import  (2005) so is there any engine management change I can make or is it a case of a decoke or something else ?
Thanks
John C
Hi John....welcome to the Forum
Generally, that engine is very efficient at burning fuel and keep emissions on the low side.
I would recommend using quality fuel and Redex prior to an MOT test but the most important thing is to keep the revs high for a distance (using a lower gear) and burn off any carbon deposits in the engine...commonly known as an 'Italian Tune-Up'
Hi Trevor,
Thanks for your response..
I have tried the quality fuel/ redex but  wonder whether its actually due to the lack of use (750 miles per year) or that  it requires  a modified EMS  to suit the UK fuel standards.
5 hours ago, Trevor said:
I think it may be down to the limited use...incredibly low annual mileage!
Yes its probably once or twice  a month in the summer  and it stays in the garage most of the winter so I guess I should just get out there with the top down and   use it more often.
