Hi Everyone
I am Australian living in Sweden and have no forums up here and wanted to ask some advice
I have a 2015 CR-V Auto 9 speed diesel,about 40000kms on the clock
I have called a number of dealers here with no one knowing an answer
The issue is the vehicle wont go into park by pushing the park button,only when you turn the motor off
Have tried pushing brakes harder disconnecting the battery ,moving gears manually etc
Has anyone else experienced this and if so what was the issue
Many thanks for any answers
Rgs
Hi.....welcome to the Forum
It sounds like a default setting which only allows the Park selection when the engine is off.
A dealer may be able to alter this setting for different country requirements but sounds like it is doing what it should be doing.
many thanks for the reply
yes it will go into park once the motor is turned of but standard is you can also put it into park while the motor is running using the button I Have been doing it for 2 years but it now rarely does it,of course extended warranty just finished so im looking for a cheap way to sort it iff possible
It may be a software glitch,hoping that simple
Rgs
