  • CRV 2011 Parking sensors. Has anybody has issues with these? The light comes on  the button, the rear sensor comes on but and bleeps but does not increase as I go nearer to objects. The front ones do not respond at all!!
  • Thanks Mike
Sorry, cant help You on this one,electronics involved.
It would be worth checking all the sensors as one may be faulty.
If you switch the ignition on, engine off and select reverse gear and then 1st gear to check the fronts.
You should be able to hear a very feint clicking noise from the working sensors.....no noise = faulty sensor
