Hello,
I was stuck outside of the UK since June 2020 and could not come back until now May 2021.
The car was left in a garage all this time and was not driven/started for months.
I tried jump-starting it using a NOCO BOOST and using another car but nothing happens.
There is not even a sound, the lights don't come on.
Would anybody have any ideas?
Is this most likely just a zeroed out battery? Or am I doing something wrong?
I am using the big bolt pin on the chassis as the ground terminal.
I am really surprised that nothing happens. I would expect at least the starter motor to turn.
The car is automatic, so I can't even release the brakes without power.
The garage is super tight (I can barely get in), so not sure how to tow it if it comes to that.
Any similar experiences? Any insights greatly appreciated.
Hi....welcome to the Club
I would say that the battery has completely expired.
I have brought them back to life by using a Battery Conditioner (which I use to maintain the battery on my bike) and this discharges and recharges in a process which will restore the battery.
May take a week for the de-sulphation process to complete.
Alternatively, buy a new quality battery and fit to the vehicle which will resolve the issue more long-term
Hi - you shouldn't need power to release the brakes. As it's an automatic and the battery is flat, the gearbox will likely be stuck in Park. The procedure for releasing it is -
New: Emergency Park Release - 9AT
When the engine cannot be started due to a dead battery, transmission failure or engine trouble, the 9AT transmission will be locked in park (P) and the vehicle
cannot be moved. In the case of a dead battery, recharging the battery and restarting the engine will allow the gear position to be changed. When you need to move the vehicle immediately in an emergency or when the engine cannot be run, you can
disengage the parking lock in the transmission by
following the procedure below.
1. Make sure the vehicle is on a firm, level, and non-slippery surface and apply the parking brake fully.
2. Leave the ignition switch in position (I) Accessory, and make sure the steering lock is not on by turning the steering wheel.
3. Open the bonnet.
4. Insert a screwdriver into the hole in the shaft of the parking release bolt (A) and swing the screwdriver anticlockwise to loosen the parking release bolt.
The parking release bolt is now loosened.
5. Insert the screwdriver in the screw head of the parking release bolt and rotate the bolt (B) until it contacts the stopper (C).The lock is now released and the gear has been shifted from (P) to (N).
6. Move the vehicle to a safe location as required.
7. When done, be sure to rotate the parking release bolt clockwise to return it back to the original position and then, swing the screwdriver inserted in the hole in the shaft of the bolt clockwise to firmly tighten the bolt so that it may not be loosened.
Once you've done this, you should be able to push/pull the car out the garage.
