Hi again.
I've just had an mot health check done on my 2002 HR-V and the found the following issues:
- Both Rear Tyres
- Oil Sump Leaking (Gasket?)
 - Both rear Anti-roll Bar Links
- Corroded Underside.
I'm not too bothered about the majority of it, but the sump is concerning.  Will it be  expensive to fix?
  • 3 weeks later...
Did you resolve the leaking sump issue?
If not, then the fact that there is corrosion on the underside listed as an advisory then it would suggest that quite possibly the sump is also corroded which is potentially dangerous and will lead to engine failure.
  • 2 weeks later...
I did.  It turns out that there was no leak - the previous garage spilt some oil during it's last service.
Haven't done the corrosion yet, but got the rest fixed for £140, so all is well. 🙂
