Splop Posted August 26, 2021 Posted August 26, 2021 Hi again.  I've just had an mot health check done on my 2002 HR-V and the found the following issues:  - Both Rear Tyres - Oil Sump Leaking (Gasket?)  - Both rear Anti-roll Bar Links - Corroded Underside.  I'm not too bothered about the majority of it, but the sump is concerning. Will it be expensive to fix?
Trevor Posted September 13, 2021 Posted September 13, 2021 Did you resolve the leaking sump issue? If not, then the fact that there is corrosion on the underside listed as an advisory then it would suggest that quite possibly the sump is also corroded which is potentially dangerous and will lead to engine failure. Â
Splop Posted September 22, 2021 Author Posted September 22, 2021 I did. It turns out that there was no leak - the previous garage spilt some oil during it's last service.  Haven't done the corrosion yet, but got the rest fixed for £140, so all is well. 🙂
Trevor Posted September 24, 2021 Posted September 24, 2021 Good result all round then! 🙂 Thanks for giving us the feedback
Register a new accountSign in
