Nigel Posted October 24, 2021 Share Posted October 24, 2021 Just purchased a 14 plate CR V and I've noticed the air vents on the back of the center arm vest are not moving. Is it an easy job to remove these vents? Thanks . Quote Link to comment Share on other sites More sharing options...
Trevor Posted October 25, 2021 Share Posted October 25, 2021 They should pull out from clips. May require moderate force but not enough to break unit Quote Link to comment Share on other sites More sharing options...
Nigel Posted October 25, 2021 Author Share Posted October 25, 2021 Thank you I will give it a go in the morning. 1 Quote Link to comment Share on other sites More sharing options...
Nigel Posted October 29, 2021 Author Share Posted October 29, 2021 On 10/25/2021 at 10:02 AM, Trevor said: They should pull out from clips. May require moderate force but not enough to break unit All fixed,a couple of the vanes had become dislodged and jammed. Easily removed and replaced with one vane needing a small screw from above to keep it in place. Thanks for the info.😁 Quote Link to comment Share on other sites More sharing options...
