Please can anyone let me know whether my car, a Honda 2007 2.2ltr ex i-ctdi is 2 or 4 wheel drive as I cant find it anywhere. Thank you.
Hi Mark
Mine is a 2008 EX Manual Petrol Mk3 and is a 4 wheel drive, I would suggest a quick call to any Service Manager at Honda . give them your Reg Number and they will be able to answer this for you straight away.
Best Regards
BAZZER RN 1
It is a 2wd and 4wd all at the same time!
Basically, it runs 2wd (on the front) and then if the traction disappears on the rear then the 4wd comes in to drive the rear axle to gain traction (assuming the tyres are up to it)
It works hydraulically and most of the time you won't know its there except for when you turn onto your driveway and if the fluid needs replacing you'll hear a clonking noise
Thank you Trevor, that has solved one problem and explains why some people say 2 and some say 4 wheel drive.
