new member
Hi, just joined. Have owned Honda's since 1996. Currently on 7th Honda Legend, a 2008 version. Great cars until you need parts.
Thanks to you both.
I do like my hondas.
As seems to be the case quite often on these forums, I'm looking to source parts/information, so if anyone can help it would be greatly appreciated.
Just had front n/s lower suspension arm replaced because the ball joint was worn...part cost me £670. I'm now needing to replace front o/s one, and the 2 rear hubs (again because ball joint worn). I've priced them all with Honda and parts are going to around £1500 plus VAT plus fitting.
Does anyone know if the ball joints can be replaced on their own (without replacing hub/suspension arm), or, apart from Honda, is there anywhere else these parts might be sourced?
Thanks
