Judder on take off gets worse when hot. Auto HR-V 1.6 2002
Hello all. l was just wondering if anyone has had the same problem with their Honda car?  The automatic box works well apart from this juddering when starting from stationary. It is the same in reverse as it is going forward. Not apparent at all when Stone Cold, gets worse as the car gets hotter. So l think that precludes things like engine mounts, or box mounts. I think it needs a filter and fluid change. What do you think, am I right, or is there something more likely that you know of with the benefit of Honda experience? Please let me know, any help would be gratefully accepted.
Yep, your post is showing, weekend all out cleaning cars, if only the rain would stop!!!!
I'm sure you will get help and advice  just not from me as anything to do with under the bonnet is above my pay grade!!
To be on the safe side and to eliminate a component that will need maintenance at some point then I would recommend a transmission fluid and filter change
You at least can see how bad (if that is the case) the fluid and filter are
Thanks for your post Trevor. Yes I think your right, I will go ahead and do the oil and filter change. That also gives me the chance to see what crud is in the box. I will report back once done.
