Seems my 2005 CRV desel 2.2 CRV is after 136.000 mikes in need of a new clutch been given a priice of £1100 fitted does this seem a fair price? Its booked in for next week at the local garage I use.
Alan
Thanks Trevor, the dual mass flywheel is in the price. First time I've ever had a clutch need replacing on any car I've had.
This little CRV has a tow bar on the back don't know hpw much work she did but is it true towing does wear a clutch out quicker??
Ah that's an even better price then!
Clutches can wear faster when towing heavy weights (twin axle car trailer for example) but it is also the stop-start motion on the transmission which is being pushed to the limit unless the trailer is braked and then this can reduce the 'whiplash' on the transmission components
Thanks again Trevor for this information. Booked in for next Tues/Weds
Alan
Got the old girl back with her new clutch -Labour, Clutcn Kit, Dual Mass Flywheel, Gear Oil, and Bolts incl Vat £1,113,23 take it back in 2 weeks for a check that all is as it should be (or before if a problem).
Feels like a new car.
Alan
