My 2005 CRV has a near side (is that left or right??} leaking headlight washer, knowing  what I'm like with anything DIY is it an easy job to do and any suggestion where to get one from please, like it to be a Honda part not some Chinese bit!!!
Alan
following on from the above, I've checked the fuse, is there a relay for the washers? The rear is working but both front are not i've now found and don't really know fpr how long,
Done the headlights on dipped and all the other tests
Alan
I'm sure it takes the water feed from within the front windscreen washer reservoir (when the lights are on and the washers are applied
Parts would be OE and no longer available so I imagine so a scrapyard would be best source for replacement jet
