1998 Civic Aerodeck 1800 VTI
Still working on this, Distributor fitted so car running now. MOT was due Jan 2026 so put it through and failed. Had the Front Offside CV Gaiter replaced last MOT, this time Front Nearside needs doing. Also ABS and SBS lights are on. Going to cost a bit to continue and make this road worthy.
Preventative Maintenance
what is this? 2024 model
Who remembers these?
New to Honda
Water in boot MK4 CRV
Dim low beam
- Remember this?
Dishonesty or Not???
- The old girl!!
