	Walk away auto lock function not workingYerman replied to Maurice j's topic in Honda e / Honda e:Ny1 Vehicle does not lock after walking away following option of right button. What page is it indicated otherwise? Ian
	FREE RADIO CODESFelin replied to OLSTERMEISTER's topic in Honda Audio / Video / Electronics / Security Systems If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you
	Hello from Honda Jade 2015 hybrid 1.5 petrolSlothenlysloth replied to Artur White's topic in New Members Introductions Hi Artur, have you still got the jade and need parts? Brian
