Who remembers these?
1998 Civic Aerodeck 1800 VTI
New to Honda
Water in boot MK4 CRV
Dim low beam
- Remember this?
Dishonesty or Not???
- The old girl!!
- FREE RADIO CODES
If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you - The old girl!!
