  2. I'm selling my Honda FR-V due to moving abroad. It's been well maintained and has a new MOT and full service history. PIctures won't upload here because they're too large, see advert on Gumtree. Located in NW London. Please PM if interested.
  3. Loved the adverts of the era as they were memorable - even after 50 years I can still sing the song that was played or the taste of the drink, etc.
  4. Last week
  5. Many thanks for the advice, the garage have sourced a new one so at least the car is still on the road. Is it alright to ask peeps what they think it might be worth if I were to attempt to sell it? Mum bought in new in 1998, 105k on the clock now and well looked after. Hope this is ok
  6. Hi Ivan....welcome to the Club I'm sure you will be pleased with the Jazz and its reliability and build quality Good to have you onboard!
  7. Earlier
  8. I have found water drips from the air pressure vent ending up on the floor also. Have new one ready to replace and seal in! This is a 2017 CRV. Should add that I have been a CRV driver since 2005 and this is the first one to show a waterleak.
  9. Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? Thanks
  10. Any upgrade in bulbs is good in my opinion. Whether they bring a noticeable difference to the table may be good but unlikely to be any worse than the standard halogen bulbs
  11. Maybe worth increasing the pressures by a couple of psi to see if this extinguishes the warning. You can always let out some air but also good to check you don't have a slight leak on one of the tyres. Resetting the pressure settings on the vehicle may just be masking a fault in one of the tyres Also, ensure you check the tyres when cold
  12. Steve replied to Alan gsd's topic in The Lounge
    I used to love Jasper
  13. That appears to be the earlier version with single oxygen sensor that only measures earlier Euro standards emissions. The later version which is on the car measure both pre and post catalytic converter oxygen levels to compare and adjust feeling to optimise and measure the efficiency of the cat.
  14. Hi @Maurice j I have attached a PDF for you to look over to do some checks for your locking issue. Honda_eNy1_WalkAway_Lock_Troubleshooting.pdf
  15. Steve replied to Alan gsd's topic in The Lounge
  16. 8520jason replied to tonydee's topic in 1984 to 1992 CRX
  17. Must have missed this , nearly a year ago!! What do you use
  18. Hi Wuzhee, I have fitted replacement upper arms and adjusted them. On checking rear wheel toe, the nearside was showing it was toeing in. Worked out the 10 point nut has nothing to do with toe, its adjusted by slackening locking nut, item 1, then adjusting via item 2. Item 3 is an offset washer and fixed plate, by turning item 2 the offset washers contact with fixed plate 'moves' the arm. I setup a DTI and adjusting item 2 by approx 10minutes (on a clock face) I achieved 0.2mm change to the toe, where I was measuring it. I rechecked both rear wheel toe's and are now at a setting more in keeping where it should be, i.e. slight toe-in. For info turning item 2, near side arm, makes the wheel toe more in an outward direction measuring from the center point of the wheel facing forward and measuring off tyre wall. Im aware tyre walls are inconsistent in their shape however as the wheel was locked and the DTI remained fixed then a true reading was achieved. Thanks to everyone for their assistance to me.
  19. I would imagine it would last a great deal longer if the fluid and filter were changed in the transmission which quite often is neglected from service and maintenance routines
  20. definitely the wisest and cheapest repair
  21. a fine car throughout the years and the different generations of the CR-V
  22. Vehicle does not lock after walking away following option of right button. What page is it indicated otherwise? Ian
  23. Hi...welcome to the Club Fantastic car to own - haven't seen one on the road in years. Good to have you onboard
  24. The alternator will be engine ecu controlled also i think.
  25. Hi all. thanks for the in. i have Civic 1.6 Dtec. Love the car hate the gremlins. auto stop start issues are killing me. £600 down with new alternator, new battery and now new battery sensor and it still isnt working properly. Very intermittent but mostly not working. car has been on OBD and there are no faults showing. Car has been told it has a new battery. Can anyone throw some light on this?
  26. If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you
