  2. Vehicle does not lock after walking away following option of right button. What page is it indicated otherwise? Ian
  3. Hi...welcome to the Club Fantastic car to own - haven't seen one on the road in years. Good to have you onboard
  4. The alternator will be engine ecu controlled also i think.
  5. Yesterday
  6. To clarify..... there is a 10 point nut on the rear lower arm, this provides adjustment for the rear Toe. Ive found the specs and on one occasion , during 4 wheel alignment it was adjusted. Can anyone provide any further information about the process, socket size etc. Direction of nut rotation vs toe in or out as I hope to be able to make this adjustment myself. Most other Honda's appear to have 3 bolts securing said arm. Thanks
  7. Hi all. thanks for the in. i have Civic 1.6 Dtec. Love the car hate the gremlins. auto stop start issues are killing me. £600 down with new alternator, new battery and now new battery sensor and it still isnt working properly. Very intermittent but mostly not working. car has been on OBD and there are no faults showing. Car has been told it has a new battery. Can anyone throw some light on this?
  8. Earlier
  9. OK, so mine's done 113k, what's the highest on here?
  10. It's has done well for 20 years so a hole about the size of a pin head is good going, so think my spot of glue will do the job for now.
  11. If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you
  12. I think if they are original roof rails and they are now 19 years old and I would therefore place as little weight on them as possible to be on the safe side
  13. https://en.wikipedia.org/wiki/Honda_CR-V
  20. things seemed so much easier back in the day - as long as the tyre was round then it was fine 🙂
  21. I think some of them are making a revival - at least in name though Lost too many good brewerys over the years (Ringwood Brewery my local one has now closed) :-(
  22. Alan gsd
  23. It should fit the apeture but Halfords stock kits to ensure the wiring and fascia are suitable
  24. I agree with you Alan, it was by far the best of all the generations so far
