  2. Hi all, I have just inherited a 1981 Honda Civic Hondamatic 3dr in Shetland White with a blue interior. My grandad bought it new, grandmother took it on when he passed now left to me following her passing. Looking to get it back on the road properly following a video made by The Brake Show. Any help/advice/parts is greatly appreciated. Thanks, Sean
  3. Earlier
  4. OK, so mine's done 113k, what's the highest on here?
  5. Hi, my vehicle is suffering rear inner edge tyre wear. I am aware there is some adjustment that can be made on the lower arms, my question is - is there any adjustment that can be made to rear wheel alignment. I believe that the 'adjustment ' nut impacts on the rear camber and is adjustable for each wheel. Anyone can provide some more information on the subject or point me in the right direction ? My vehicle has clocked up 145k miles and has always been a bit heavy on rear tyres, even after 4 wheel alignment at a reputable garage chain, in fact on that occasion an adjustment was made but insufficient adjustment to be within tolerance. The cars history is known and no accident damage that could account for my problem. BTW the car drives fine and handles well in any weather, its just I fancy having a go at getting it to be more gentle on tyres. Thanks Chris.
  6. It's has done well for 20 years so a hole about the size of a pin head is good going, so think my spot of glue will do the job for now.
  7. If you are still doing the radio codes, please can you get me the code for S/N 28086508. I would be extremely happy if you can as my wife reminds me every day. Thank you
  8. I think if they are original roof rails and they are now 19 years old and I would therefore place as little weight on them as possible to be on the safe side
  9. https://en.wikipedia.org/wiki/Honda_CR-V
  10. that's a brilliant ad and wished other manufacturers could do something this ingenious - now they just focus on the lifestyle aspect and forget its even a car.
  11. I've not had much luck buying from China via Ebay lost a few ££££££ so wouldn't chance it unless you can afford to take a chance.
  12. Hi all my 2009 Frv reversing unit failed so I bought a cheap no make system, drilled out existing sensors and fitted new sensors and wires it in, a wire to reversing light and wires to the beeper ( fixed next to existing sounder). I think I got the 'kit' for under £15.00 and apart from a little faffing around its been working for the last few years. I didn't have the equipment to check the original control unit or each individual ultrasonic sensor so it seemed to logical cheap fix.
  13. Hi Artur, have you still got the jade and need parts? Brian
  14. I can supply these custom made for a negotiable price if I have 1 or 2 more buyers. impossible to get in europe. not stocked OEM: 73111T4R003
  15. Hi, Desperately looking for a replacement front windscreen. The only 2 breaker jades in country don't have one intact. c.2K from japan!!! 6 month lead time. Have found someone in UK who can make a minimum of 5 of them but would need a couple of other buyers to justify. OEM: 73111T4R003 Maybe someone knows of an unlisted broken Jade somewhere? as I can have a guy who can remove the glass safely. any help appreciated. or am looking at a write off. Brian.
  16. things seemed so much easier back in the day - as long as the tyre was round then it was fine 🙂
  17. I think some of them are making a revival - at least in name though Lost too many good brewerys over the years (Ringwood Brewery my local one has now closed) :-(
  18. Alan gsd
  19. It should fit the apeture but Halfords stock kits to ensure the wiring and fascia are suitable
  20. I agree with you Alan, it was by far the best of all the generations so far
  21. Finally found the problem. It was my passenger’s rare ABS sensor, which had debris and was cleaned properly. All warning lights never came back.
  22. It's https://www.ebay.co.uk/itm/197475366333?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3De6234bdbf97d43278ddcbf9164e6c802%26pid%3D101224%26rk%3D4%26rkt%3D5%26sd%3D205606678374%26itm%3D197475366333%26pmt%3D0%26noa%3D1%26pg%3D2332490%26algv%3DDefaultOrganicWebV9BertRefreshRankerWithCassiniEmbRecall%26brand%3DHonda&_trksid=p2332490.c101224.m- It's not mine for sale!! you could ask the guy in Doncaster the same question hahahahaha
